Author Topic: Cooling Fan running all the time  (Read 4500 times)
blee
« on: February 03, 2011, 03:52:00 AM »
My cooling fan is running all of the time.  I looked it up and I believe that the relay is the problem. Does anyone know where you can get one or is the same relay on another car i.e. 323?  Thanks
« Reply #1 on: February 03, 2011, 04:04:00 AM »
The sensor in the thermostat housing is usually to blame.
Just a side note - have you removed the AC system? Are any fuses, including those for the AC blown?
The fan sensor is on the thermostat housing, I think facing toward the driverside fender. It has a rectangular black connector, with a spade terminal.
I dont think the 323 uses that particular sensor, check on Rockauto.com you can still buy them new for under $15, they have parts interchange there as well if you're going junkyarding.
Aftermarket part #'s:
STANDARD MOTOR PRODUCTS Part # TS113
KEMPARTS Part # RF22
ORIGINAL ENGINE MANAGEMENT Part # 8455
Hope this helps
-Rocket
« Reply #2 on: February 03, 2011, 05:19:00 AM »
Could be a fuse too, can't hurt to check them.
blee
« Reply #3 on: February 03, 2011, 11:57:00 AM »
Thanks for the help. When I get home tonight I will check it out.  I will post when I figure it out. Thanks.
Re: Cooling Fan running all the time
« Reply #4 on: April 29, 2016, 05:36:10 PM »
I figured it out. Bad ground between the thermostat housing and the block. Just back the thermostat bolts out and back in until it turns off.
« Last Edit: April 29, 2016, 06:05:24 PM by Gaz »
