Author Topic: Circlip? I can't find one.  (Read 3581 times)
shoeish
« on: November 29, 2010, 01:14:00 PM »
And people look at me like I'm stupid when I ask for a "circlip."
XR2 Turbo
Thanks!
« Reply #1 on: November 30, 2010, 11:49:00 AM »
I recently threw away my old axles. I bet russ has one laying around to pop the clip off of
shoeish
« Reply #2 on: December 01, 2010, 05:12:00 AM »
I am just going to re-use the old.
Thanks!
« Reply #3 on: December 01, 2010, 05:28:00 AM »
To be honest unless the clip is damaged, there's no reason to change it.  And if it was, you'd be better off changing axles anyway.
« Reply #4 on: December 01, 2010, 12:04:00 PM »
Agreed...if it is off...might as well replace
« Reply #5 on: December 01, 2010, 01:49:00 PM »
Well that's just it.  If the circlip is broken, the axle would wobble about, which would damage the axle VERY quickly.  They are pretty much lifetime clips, you can't remove them off the axle to replace them.  The clip is only bad if you drive it and notice it.
« Reply #6 on: December 01, 2010, 03:40:00 PM »
You can remove them. I have had to do so for various reasons before. Its tricky, they're tempered spring steel. The FSM actually states to replace them every time you service the axle, I've reused them many times without any issues
shoeish
« Reply #7 on: December 01, 2010, 04:15:00 PM »
I would love to replace, but can't find a new one!
