June 23, 2024, 03:42:46 PM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
General
General
power steering belt
« previous
next »
Pages: [
1
Print
Author
Topic: power steering belt (Read 4539 times)
Piojo
Full Member
power steering belt
on:
January 16, 2012, 09:09:00 AM »
how do i install the power steering belt? do i remove a pulley or can just mount the belt withou removing a pulley
Administrator
Old-Timer
91 BPT AWD Capri & 1991 XR2
power steering belt
Reply #1 on:
January 16, 2012, 10:18:00 AM »
Loosen the tensioner on the front of the power steering pump (its part of the bracket that sticks out) and the new belt will just slip onto the pulleys, don't need to remove anything at all.
The tensioner has two bolts, one is a 14 (on the side) that locks it and another 12mm (on the top) that adjusts the belt tension
Guest
power steering belt
Reply #2 on:
January 16, 2012, 10:19:00 AM »
Look at the power steering pump, there should be 2 bolts on the manual tensioner. The belt tension is controlled by 2 bolts on the power steering pump, one on the side and one on top, just loosen them to get the belt off.
newboyracer
Jr. Member
power steering belt
Reply #3 on:
January 16, 2012, 06:29:00 PM »
You will probally have to loosen the large silver bolt close to the engine as well (also a 14mm) in order for the power steering pump to move free enough to put on the belt.
Time is the greatest teacher, Unfortunatly it kills all it\\\'s students.
Print
Pages: [
1
« previous
next »
General
General
power steering belt
