Author Topic: Chassis grounds  (Read 3585 times)
Chassis grounds
« on: June 12, 2022, 06:57:13 PM »
I'm at a loss looking for the chassis ground for the turn signals. I found the one to get the fog lights going and the one that kept it from starting. I can't find the one for the turn signals. I can ground the bulb housing and they work, so I know it's a corroded ground. I found one on the front and back of the head on the passenger side and one on the VAF and one in front of the distributor. Somewhere there much be another one. HELP!
Re: Chassis grounds
« Reply #1 on: August 12, 2022, 10:29:55 AM »
Jack....there are ground leads up under the dash as well. There is one on the bottom of the steering column that I found recently while tearing down a parts car.
Re: Chassis grounds
« Reply #2 on: August 13, 2022, 08:45:17 AM »
Thanks, the latest problem is the wipers won't turn off. Hopefully that will be the switch.
