Author Topic: Alternators, how much power can you get  (Read 2159 times)
DarkAngel
    • Build Thread
« on: September 26, 2016, 08:49:49 AM »
I'm looking at pumping up the capacity of my alternator in my SE XR2... I'm putting in a dual battery system... yes, I have lots of electrical accessories going in...
Firstly there is the flip out LCD screen headunit, a miracast wifi unit with usb charger, gps tracker alarm, pumping amp sounds... and heated seats... running off the dual battery.
Question is, what other alternator options are out there for the Capri ?
And what type of replacement alternator do you use, and how much amperage does it run at ?
Current Project XR2 SE
To Do
tracker gps, respray
Re: Alternators, how much power can you get
« Reply #1 on: September 26, 2016, 07:01:51 PM »
DarkAngel
    • Build Thread
« Reply #2 on: September 26, 2016, 07:22:10 PM »
Awesome, 85amp on the older 90 model Capri (the one with the fan on the alternator)
I noticed some US high power alternators on ebay rewound up to 130amps !!!
That would go nicely with an Optima 750+ cc amp battery.
To Do
