Author Topic: sway bar end links  (Read 3845 times)
010sambo
    • 1992 Xr2 1995 F150
sway bar end links
« on: January 08, 2016, 05:13:40 PM »
I'm rebuilding the front end of my 92 xr2 and
I can't find anyone around locally
That sells the rubber grommets for my sway bar
End links. Has anyone found a cross reference to a like for like part
Maybe a kit or something, thanks for your input. I really need to get this jewel back on pavement, my 95 f150 is drinking me dry while she sits patiently .
Re: sway bar end links
« Reply #1 on: January 09, 2016, 01:16:15 AM »
I think I got mine from auto zone.  BTW you can run the car safely without the bar, most automatic capris never had them installed at the factory...
« Reply #2 on: January 09, 2016, 02:49:14 AM »
Energy Suspension end link kit  # 9.8122 is the part you're looking for.
« Reply #3 on: January 09, 2016, 11:44:24 AM »
I got some from Russ, but they were too long and much too large in diameter.  I also got the bushings and they were too large in diameter.  Don't know what the problem was.
Jack Byd
010sambo
« Reply #4 on: January 09, 2016, 04:07:32 PM »
The part #mentioned from energy suspension online says it's 2.55" I measured my old ones and the bolts are 4" long
Comparing the diameter and length Should I order part # 9.8125 or 9.8117.
« Reply #5 on: January 09, 2016, 07:55:42 PM »
The sway bar end link sets are not measured by the bolt length.
Kit #9.8122 measurement of 2.55” is for the distance between the control arm and the sway bar. After you add the outer 5/8” top and bottom bushings, nut, and washers, the assembly will be over 4 inches long.
The bolt length of kit number #9.125 will be over 6” and will swing your sway bar ends into the axle.
010sambo
« Reply #6 on: January 10, 2016, 07:50:27 AM »
Thanks chrispoe ,
Advance tried to cross reference some from a mazda. The bolts and the bushings were larger in diameter.
« Reply #7 on: January 10, 2016, 04:14:33 PM »
Found the receipt, I put Duralast SL255HD on my 93 xr2, different diameter but fit great, less than $10/side at autozone...
