Pages: [1] 2 3
Author Topic: installing guages  (Read 8318 times)
Heavensheros
installing guages
« on: July 12, 2009, 12:52:00 PM »
i am having trouble installing an air/fuel ratio and boost gauge into my car, Where can i run the wire into the engine bay to mount to my a pillar gauge pod. if anyone has pictures to show where i hook everything up or at least instructions that would be amazing.
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
Heavensheros
installing guages
« Reply #1 on: July 12, 2009, 02:02:00 PM »
also where the vacuum line is to install the boost gauge too and where to splice the air fuel sensor
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
installing guages
« Reply #2 on: July 12, 2009, 03:04:00 PM »
you can use any of the rubber grommets on the firewall. when i ran my car stereo i put it through the main harness on the passenger side. 4ga wire fit in the extra rubber no problems. that might be a long ways to run it. i am gonna order gauges myself really soon so i will be doing the same. there might be something behind the main gauge cluster. i am removing mine this week to put on the white face gauges. i am hoping to find one there. as for splicing the af guage. you can tap into the wire at the O2 senror and run it with the vacuum line or  do it right at the ecu.
installing guages
« Reply #3 on: July 12, 2009, 03:09:00 PM »
did you get the pod that i sent u the link too?
Heavensheros
installing guages
« Reply #4 on: July 12, 2009, 05:32:00 PM »
i will be getting the pods but i do not know how to hook up the boost gauge i used a T connector and connected it to the hose going into my BOV will that work ? my car when running idle has about 20 psi vacuum havnt had chance to drive and check boost to see if that is a good place to connect and also i found where to hook up the A/F but where would be the best place wo put the white and red wire ?
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
installing guages
« Reply #5 on: July 12, 2009, 05:40:00 PM »
i always hook my boost up to the fuel pressure regulator.
if those are for the lighting...then one is ground and the other is power. instructions should say which one is what.
remove the dash bezel and you can tap into any of the wires that get 12v when you turn on your lights.
if it is one that require constant 12v then just find one with 12v when the car is on. make sure it has no volts when car is off. if your hesitant to cut wires around there. then you can always run them from the stereo
Heavensheros
installing guages
« Reply #6 on: July 12, 2009, 06:14:00 PM »
which hose is the boost regulator
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Heavensheros
installing guages
« Reply #7 on: July 13, 2009, 12:43:00 AM »
so i installed the A/F gauge and when car is on the last light on the Rish light is bright and all the other lights on the gauge are flickering. what could i have done wrong ?
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
khrys771
installing guages
« Reply #8 on: July 13, 2009, 02:38:00 AM »
what type of afr gauge is it?
installing guages
« Reply #9 on: July 13, 2009, 10:30:00 AM »
Have you taken it out on the road yet? At idle the sensor is cold and does not give a clear signal, and it will cause several lights to illuminate at once. If its doing it during driving then your O2 sensor could be bad, or your signal wire isnt connected well/properly.
installing guages
« Reply #10 on: July 13, 2009, 02:39:00 PM »
fuel pressure regulator....hooked up to the fuel rail. have vacuum hone on it..tap it there for the boost gauge
installing guages
« Reply #11 on: July 13, 2009, 05:45:00 PM »
when you remove the overboost switch use the spare bung to hook up the guage...
not to be a shit, but i wouldnt use the line to the fpr... it sees only vaccume.. besides that thing is very important and if by chance you develop a leak at the guage.. the fpr might malfunction and cuase a lean condition (not good)
bov line will work but guage will be slow and inaccurate when the bov acuates...
for a good solid trustworthy reading a bung on the intake is the only way to go....
installing guages
« Reply #12 on: July 14, 2009, 02:25:00 AM »
i been told the opposite. you will know there is a leak on the vacuum because the gauge will not read correct. i have done it on my DSM, cedric, 240 and skylines all at same place with no issues. its quick responding there as well. if it leaks you will know
Heavensheros
installing guages
« Reply #13 on: July 14, 2009, 11:25:00 AM »
ok i solved the problem with the afr gauge. the splicer that came with the gauge did not clamp down all the way and i had to use pliers to clamp it down but now it all reads well at idle, no chance yet to put out on the road because i am in WV and also i got the boost gauge hooked up to the regulator and it seems to be running ok idle is 20 PSI vacuum
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
installing guages
« Reply #14 on: July 14, 2009, 12:46:00 PM »
sweet
Pages: [1] 2 3
