Author Topic: timing numbers  (Read 4282 times)
mcanchola2
timing numbers
« on: September 11, 2011, 01:18:00 PM »
ok so i was trying to correct my timing on my n/a capri and i was just wondering about the timing numbers, it has marks between 10 and T. are the small marks going by 2 degrees each one??
heres a pic of what im talking about and were i left my mark
timing numbers
« Reply #1 on: September 11, 2011, 01:36:00 PM »
You want to be up higher, I think the number is 12 on NA capri's.
T is top dead center, then there's 10 and 20.
timing numbers
« Reply #2 on: September 11, 2011, 03:19:00 PM »
Quote
Incorrect. Timing on an N/A is 2° BTDC
XR2 is 12° BTDC.
FSM states a tolerance of ±2° - so you are okay at the 4° you have there.
timing numbers
« Reply #3 on: September 11, 2011, 04:10:00 PM »
I misread
mcanchola2
timing numbers
« Reply #4 on: September 11, 2011, 07:47:00 PM »
thanks guys for your help
