Author Topic: Check Engine Light No Power 3K RPM Help  (Read 5047 times)
« on: February 12, 2009, 03:51:00 PM »
1. Where in the world is the port to check the codes? I went to auto zone and they had no idea too. we looked all over.
2. Last night while driving on the freeway i got the light to come on. car ran fine. i pulled over restarted car and ran fine home no light. In the morning i drove to work with no problems as well. On the way home from work i noticed it was cutting out in the 3000 RPM range. Only a little. got home changed and drove it some more. it would get worse and worse. sometimes it would die when i come to a stop and i got the light about 3 times.car would sputter and buck when hitting 3K RPM. It already has new plugs and wires. new battery, rechecked all wires all were fine. i left auto zone and stopped to get gas since i was under 1/4 tank and when i left the gas station it worked great...could i of had bad gas and i got water in the tank? i added some of that fuel cleaner on the last tank so i can emission test it. it said to run it on one tank then refule and do the test. i just fine it so weird that i add gas and it works fine....
Help and thoughts?
Yuri
« Reply #1 on: February 12, 2009, 05:23:00 PM »
the ports are under the hood near the firewall... good luck with having advance auto have the right connectors... they lost the ones for mine 2 years ago... there's either 2 or 3 things they gotta plug into
someone else here will be able to take a pic and circle where they are for ya, i don't remember
« Reply #2 on: February 12, 2009, 05:55:00 PM »
i did notice 3 connectors by the emissions/fuel canister on the passenger side. is that where it is at?
a photo would be awesome....
is there a way to short it out and count the light blinks ?
« Reply #3 on: February 12, 2009, 07:12:00 PM »
Hey Gost! I can't help you on the hook up for a code reader but there is a method to make the blinks and the number of blinks clues you into what system is giving you trouble. I think you're on to something but not water because it would permanately fouled your fuel filter. It may have to do with your fuel pick-up not extending down far enough into the gas tank. Hence things working alright after putting more gas in the tank.  Gus
« Reply #4 on: February 12, 2009, 08:48:00 PM »
Check your O2 sensor.
« Reply #5 on: February 13, 2009, 01:17:00 AM »
how can the o2 sensor work on how much gas is in the car?
« Reply #6 on: February 13, 2009, 02:52:00 PM »
i picked up a fuel filter and O2 Sensor today, car ran fine today with out any problems. so weird that all i did was add gas and it was fine.
i really need someone to tell me how to retrieve the codes so i can get them.
« Reply #7 on: February 14, 2009, 12:43:00 PM »
been days... no one know how to check the codes on this thing?
« Reply #8 on: February 14, 2009, 07:46:00 PM »
You have to jump the diagnostic connector on the firewall and then KOEO (key on engine off)
The CEL will blink any codes that may be at fault. As far as I know the MECS system does not store codes.
« Reply #9 on: February 14, 2009, 10:14:00 PM »
where is the connector and what does it look like? wire colors?
what pins do i short out?
« Reply #10 on: February 15, 2009, 05:42:00 AM »
I'm trying to find the diagnostic procedure. Its on here somewhere but I cant find it.
« Reply #11 on: February 15, 2009, 05:53:00 AM »
Here the link to the codes is on the main site: http://teamcapri.com/howtos/cartroublecodes.html
And the diagnostic port is one of these near the Evap canister:
http://www.werbatfik.com/uplimg/boostcut3.jpg
I want to say its a green connector?
« Reply #12 on: February 15, 2009, 06:34:00 AM »
ok so short out the plug, turn on the car but not start and then the computer should spit out a code?
« Reply #13 on: February 17, 2009, 03:54:00 PM »
well car did same t hing when it got to just less then 1/4 tank. no engine light. only thing i can think of is there is a hole in the fuel return line above the pump. when there is enough gas in the tank to cover the hole works fine....then when it uncovers it will starve. guess i will just gas up at a 1/4 tank until i have time to get in there to check on it. might as well upgrade the fuel pump while i am there..LOL
riot
« Reply #14 on: February 21, 2009, 03:49:00 PM »
i know this may sound a little dumb but i had this same thing happen on a different car... it was caused by a loose gas cap of all things... i dont remember exactly what the guy at the dealership told me but it had something to do with air leaking into the tank from the lose cap...
Gauges dance and needles glow, engine speed and heartbeat grow, shifting gears through nimble thumbs, something wicked this way comes...
