Pages: 1 2 [3]
Author Topic: Gotta Break the Ignition Lock  (Read 32795 times)
Heavensheros
« Reply #30 on: March 31, 2010, 12:59:00 AM »
in fact i did getting running ... the TB gasket was a piece of shit and was thin in some spots and wet at the bottom. made my own gasket for it and i have no more problems so far
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
Heavensheros
« Reply #31 on: March 31, 2010, 01:07:00 AM »
i took the ignition key slide off and im looking at the pins and correct me if im wrong
2x BATT = connect together for battery
2x A1 = connect together for ACC 1 posistion
2x A2 = connect for ACC 2 position
1x ST = Start wire
1x P1 = ?
1x 11 = ?
1x 12 = ?
1x P2 = ?
here is a diagram
A1......A1......12..11..ST
..................................P1
BATT..BATT..A2..A2..P2
for the toggle on off i should splice into the BATT wires
for the push button start  idk yet
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Heavensheros
« Reply #32 on: March 31, 2010, 01:16:00 AM »
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
« Reply #33 on: March 31, 2010, 04:10:00 AM »
How are you going to keep the wheel from locking?
Heavensheros
« Reply #34 on: March 31, 2010, 05:33:00 AM »
when you take the tumbler out of the key it comes out in run mode so steering is unlocked and key is in accessory mode ... if i take the 2 BATT wires and run them to a switch instead of the ignition plug its cutting power so switch off key ( which is out ) will be in run position but no power turn switch on kar is in run mode ... then add push button start... ill show a pictue after my class .... also is Russ still going to your place before the MACG ?
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Pages: 1 2 [3]
