June 03, 2024, 04:47:56 AM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Tech, Repairs, Upgrades
Capri N/A 89-94
Help far from home and having problems
« previous
next »
Pages:
1
2
Print
Author
Topic: Help far from home and having problems (Read 7335 times)
Guest
Reply #15 on:
March 23, 2012, 04:50:00 AM »
Does the temperature hold good, or does it go a bit high? Also does the idle only drop when the fan is on, or can you run it down with excess accessories?
I'd blame IAC and fan motor/relay/wiring before blaming a coil of all things.
wvengr
Newbie
Reply #16 on:
March 23, 2012, 05:58:00 AM »
It will do it slightly with the highbeams on. But the worst is with the fan. The coil is close to 30 percent out of tolerance, so it needs replaced. If it doesn't fix the problem I will look elsewhere.
wvengr
Newbie
Reply #17 on:
March 31, 2012, 05:59:00 AM »
Coil helped, and I was able to get it home. Still is having some problems, but I will get those sorted out soon. Thanks for the help guys
Print
Pages:
1
2
« previous
next »
Capri N/A 89-94
