Author Topic: 94 struts  (Read 3964 times)
nepacapri
94 struts
« on: May 25, 2008, 05:44:00 PM »
I need to replace the struts on my 94 NA (auto), I've looked at the normal auto parts stores, parts ameria, auto zone etc...and they all list 90-93 struts and then they all don't have any struts for the 94.  I thought that on the 94 XR2 used a different strut, correct?  Can I use the 90-93 on mine?  Also, after 120,000 miles and 14 years should I also change out the springs?  Any other parts that normally wear out that I should be watching out for?
94 struts
« Reply #1 on: May 25, 2008, 06:50:00 PM »
91-93 struts should fit fine.
94 struts
« Reply #2 on: May 25, 2008, 06:52:00 PM »
Hey Nepa! I changed out the struts on my '94 n/a last year and if I rememember correctly, the're the same as '91-'93. I haven't checked into the '94 XR2s yet. They do have a lower suspension. I have sport springs on two of my '91s and that did not call for a change in struts.That puts them at a similar height to the '94 XR2s. Pull one out and compare. Unless you notice a sagging in the front end or you intend to auto-cross race your car, I wouldn't replace the springs.  Good Luck!   Gus.
