Author Topic: Motor Problems  (Read 3368 times)
vintage5
Motor Problems
« on: July 30, 2011, 04:13:00 PM »
Switched motor off and 10 minutes later returned and motor wouldn't start. Checked voltage going to coil and had 12 vdc. no fire coming from dist. waited a couple of days and tried it again and it started right up. Any ideas?
Motor Problems
« Reply #1 on: July 30, 2011, 04:22:00 PM »
Could be your ignitor in the Distributor. Did the tachometer bounce when you tried to restart the car? It's a little random that it would quit like that.
vintage5
Motor Problems
« Reply #2 on: July 31, 2011, 03:09:00 AM »
Thanks Rocketman for your reply. I don't remember noticing the tach while trying to crank. I remember something like this when I purchased the car. As I remember then I had turned the car off and tried to restart and it wouldn't crank but after turning the switch off and on a couple of time it restarted.
