Author Topic: Trunk mounted fuel cell  (Read 3186 times)
9193CapriXR2
« on: September 04, 2023, 10:30:22 AM »
Long time reader first time poster.
I own 6 vehicles...2 of which are Mercury Capris.
1993 Capri XR2 Turbo Cardinal red with 41,000 Original miles (Will stay completely original)
1991 Capri XR2 Turbo Cardinal red that I am just starting on modifications
I started sanding on the body this past weekend and decided that I really want to clean up the body lines by shaving the door handles and fuel door.  I ordered a 2 door popper kit so I can shave handles and key lock and looking at purchasing a 8 to 10 gallon fuel cell to mount in the trunk of the 91.  My question is has anyone done this already and know A) what rating fuel pump is required to feed fuel to the engine and B) if they have a wiring diagram to wire up the tank and pump correctly?
I want to get the engine running properly off the fuel cell before welding the filler door shut.  I also plan to remove the fuel tank, straps, and filler neck to alleviate a little weight.
If anyone has already installed a trunk mounted fuel cell was any additional bracing needed to support the 60-80 pounds of weight with the full capacity cell using 6 pounds per gallon of fuel as an estimate?
Re: Trunk mounted fuel cell
« Reply #1 on: September 05, 2023, 08:01:52 AM »
Welcome to the family. Remote door handles and truck have been done. This should help with your wiring.
https://kengranderson.com/capri-service-manual/?fbclid=IwAR07hD7yU-GI_jspyUmBORUSccsRDhkZgYjcfMxic0vhqG8H0rGHKxfKDX4
TechCapri has one also, but I found this one first.
Good luck.
9193CapriXR2
« Reply #2 on: September 05, 2023, 10:04:28 AM »
That site is legit!  Thank you for posting it.
