Author Topic: Exhaust leak at catalytic converter  (Read 1106 times)
mr_gr1mm
« on: May 16, 2022, 11:15:31 AM »
Hey guys, so my 1.6L Capri has an exhaust leak where the catalytic converter meets the downpipe. I believe the cat converter is still good, but not sure how to deal with the fume leak. Is there a simple gasket I can replace to stop the leak?
https://imgur.com/a/3yKPkcN
I also need to replace the entire exhaust pipe beyond the catalytic converter. I'm wondering if most any aftermarket piping can be installed or it is specific to the 91 Capri - also not sure if I can go with something wider? Or is that traditionally done at the exhaust tip only?
Thanks and sorry for all the dumb questions!
Re: Exhaust leak at catalytic converter
« Reply #1 on: May 16, 2022, 09:22:10 PM »
You should be able to find the gasket for purchase at the autoparts store or Rockauto
https://www.rockauto.com/en/catalog/mercury,1991,capri,1.6l+l4,1196625,exhaust+&+emission,pipe+flange+gasket+/+seal,5836
I'm not sure if there are any replacement bolt-on pipe available, you may have to consult with a local exhaust shop and have something made up.
Yes you can go bigger on the pipe if you need to
