Author Topic: Replacement Rear Struts  (Read 3759 times)
Kiwimagic
« on: April 14, 2021, 01:30:52 AM »
This has probably been asked before.
Rear Strut replacement.
KYB 232011/12 for a 1988 Mazda 323,
Will these fit ??
They will be for a 1994 SE Turbo.
I know the SE Turbo have the extra support bracket,
But to get the original struts remanufactured is nearly the same cost as the whole car,
So looking for replacements.
I have been lead to believe that these 1988 Mazda 323 ones will fit.
Or are there any others that will do.
I am replacing the fronts with KYB 243008/9, so though go with KYBs for the rear as well.
cheers
kiwimagic
redsteve
Re: Replacement Rear Struts
« Reply #1 on: April 14, 2021, 11:31:13 AM »
Hi kiwimagic,
I did a quick search on this site and found this older thread on the subject, it should lead you down the correct path.
http://teamcapri.com/forum/index.php/topic,2945.msg123943.html#msg123943
Rocketman and other similarly afflicted on this site are an incredible resource to us all, and I find a lot of what I am looking for has been discussed here somewhere along the line, or someone kindly points me in the right direction.
Best of luck to you!
redsteve
