Author Topic: Trunk Lid Struts  (Read 2328 times)
JimmyGermany
    • 1993 Capri non-turbo
Trunk Lid Struts
« on: October 18, 2020, 05:19:21 AM »
Gentlemen!
Is there any difference between the struts required for a trunk lid WITH a spoiler as opposed to one without?
My trunk (originally without a spoiler) seemed to stay open fine, now that I've replaced it with a lid with a spoiler (and without the swastika some A-Hole scratched into it), she won't stay open and I'm doing the broomhandle trick.
I don't know if these are the first ones still on there, in which case, they're allowed to slowly give up.
If looking for replacements, is there a difference?
Cheers
James
Re: Trunk Lid Struts
« Reply #1 on: October 18, 2020, 10:49:30 AM »
Yes, the XR2 does require stronger struts.
« Reply #2 on: October 19, 2020, 09:23:44 AM »
The lift struts are all the same length, but they have different force specs. According to Rockauto, without the spoiler they are 49 LBS and with spoiler they're 72 LBS.
« Reply #3 on: October 19, 2020, 06:51:27 PM »
Yep. Cheap and easy to replace too
redsteve
« Reply #4 on: October 31, 2020, 11:08:12 AM »
Hi all,
This small project is on my winter list too.
Between the brands does anybody have a preference?
And, any thoughts as to "overkill," using the spoiler rated lift supports on a non-spoiler trunk? Any perceptions as to build quality, longevity, and etcera, or am I wasting a couple of dollars?
Cheers all!
Steve
jdp
« Reply #5 on: November 01, 2020, 10:09:29 PM »
I put the wrong ones on my wife's 94 NA by mistake.  When I turned the key, the trunk lid almost took my chin off.   If you don't have the spoiler, you shouldn't need the stronger ones made for trunk lids with spoilers.
John
redsteve
« Reply #6 on: November 02, 2020, 12:11:45 PM »
Hi John,
Thank you, exactly the input I was hoping for.
NA struts it is, then I gotta drill out a broken bolt, one of the bolts that holds the front anti-sway bar to the frame....sigh...
Cheers all
Steve
