Author Topic: Would an xr2 ecu..  (Read 4270 times)
bratboy_y2k
    • cars
Would an xr2 ecu..
« on: July 12, 2019, 04:35:45 AM »
Be able to be made to run a 1.8 turbo engine? How's it been done? I'm guessing getting the right injectors to balance with the displacement would make the easy work.
Re: Would an xr2 ecu..
« Reply #1 on: July 19, 2019, 08:24:17 PM »
I touch on this in the BP swap thread:
http://teamcapri.com/forum/index.php/topic,2864.0.html
Short answer is yes, because we use a VAF meter that is volume based, it will run the BP correctly with stock XR2 injectors.
It's not ideal but it will get you up and running.
When I built the GTXR2 I used B6T electronics on the BP+T I have in it, it ran fine with good AFR's even at moderate boost levels
Long term I had plans to put my Megasquirt ECU into it but it ran well enough that I didn't bother at the time.
