Author Topic: Big Brakes, Full detail, ready for summer!!!  (Read 15170 times)
belleaudb
    • 92 XR2
« on: May 06, 2019, 12:25:05 PM »
Nice and clean! Still looks good for a car that will be 28 years old in 5 months.
New rear struts
Big brake upgrade
« Last Edit: May 06, 2019, 12:31:26 PM by belleaudb »
terrymetal
    • 1992 Mercury Capri Convertible, 1979 Ford Ranchero
Re: Big Brakes, Full detail, ready for summer!!!
« Reply #1 on: May 06, 2019, 09:49:19 PM »
Very nice ride!!  I would definitely say you are ready for the summer!!  Terry
« Reply #2 on: May 07, 2019, 09:35:20 AM »
WOW, that is nice.
Skunkwrkz
« Reply #3 on: May 07, 2019, 07:31:09 PM »
Those wheels are the SEX. Such a clean example. Thought about replacing those old rubber brake lines with Stainless Steel? I just got thru doing mine and the pedal is so much firmer. They would look great behind those wheels.
belleaudb
    • 92 XR2
« Reply #4 on: May 08, 2019, 06:29:51 PM »
I had seen your post regarding the Safebrake hoses. Did a little research and finally ordered them. I wanted to replace all the rubber hoses once I got the big brake upgrade done. I replaced the front hoses back in 2007 and the rears are original.
Will post pics once done.
LGCapri
    • 1992 Purple Capri XR2
« Reply #5 on: June 10, 2019, 07:15:56 AM »
Skunk where did you get those struts?
Skunkwrkz
« Reply #6 on: June 10, 2019, 03:43:41 PM »
I sourced them off Ebay. They are NOS Tokico HP's (commonly known as "Blues") They are for the 2WD BF Mazda 323 and bolt right on. I set up a search for them on Ebay and these turned up there.
Skunkwrkz
« Reply #7 on: June 10, 2019, 03:46:17 PM »
 Those wheels are the last word for me. Simple and elegant. Were those an OEM option in OZ?? I am sourcing some SVT wheels for a similar look that I plan on painting black and polishing the lips. In any case. Car looks great and well sorted to boot. Enjoy the sunshine.
belleaudb
    • 92 XR2
« Reply #8 on: June 12, 2019, 02:55:13 PM »
The wheels are Primax 925 which I purchased in 2008. They have been out of production for 10 years. I don't know of any wheels that are similar.
17x7 with 42mm offset. Tires are 205 40 17
No suspension modifications to allow fit.
Skunkwrkz
« Reply #9 on: June 12, 2019, 06:26:43 PM »
Cool. I have a great idea for something similar using the 16 inch X 6.5 SVT Wheels from the Ford Contour.
« Reply #10 on: June 12, 2019, 07:39:47 PM »
belleaudb, she is looking mighty fine. Could not run wheels like that here in PA, they'd be bent & broken in an afternoon. Have had to hammer out two of the steelies on my hyundai this year already.
Hmm, don't the Contours use a weird bolt pattern?
Looks like it is 4x108
Skunkwrkz
« Reply #11 on: June 12, 2019, 09:04:01 PM »
It is. Yes. But the offset is like +49 and so a 15-25mm hubcentric adapter will take care of that in short order. I've already rolled the fenders in preparation for them. They also are DIRT cheap and relatively lightweight.
FALSE PROTAGONIST
    • 1990 Ford Capri turbo, 2002 BMW 530d
« Reply #12 on: June 17, 2019, 08:44:09 AM »
Hi there, nice Capri, looks crisp in white. Are you from Aus and now living in the US?
I noticed you had a Victoria plate on the front of your car in one of the shots. I am an Aussie living in London, I just made a post about my car I boguht from QLD.
http://teamcapri.com/forum/index.php/topic,4277.0.html
« Reply #13 on: June 17, 2019, 09:15:19 AM »
Yes, that is a beautiful, well sorted car.
jdp
« Reply #14 on: June 17, 2019, 11:11:12 AM »
Beautiful car!
John
