Author Topic: Turbo questions  (Read 2250 times)
LGCapri
    • 1992 Purple Capri XR2
Turbo questions
« on: October 11, 2018, 01:44:51 PM »
Does the '92 Capri have an intercooler? If so where is it? Also, is it possible/practical to have a blow-off valve on the turbo along with the wastegate?
LGCapri
Re: Turbo questions
« Reply #1 on: October 11, 2018, 02:54:53 PM »
Ok so I've looked into it and realized how strange this question is. How about this: Can anyone give me advice as to where I could put a blow off valve?
Re: Turbo questions
« Reply #2 on: October 12, 2018, 12:21:48 AM »
The Capri has a bypass valve from the factory. It is connected to the crossover pipe on top of the valvecover. You can remove it and add your own BOV there. The return end must be capped off then
LGCapri
Re: Turbo questions
« Reply #3 on: October 14, 2018, 10:16:58 AM »
Is there a diagram on Tech capri as to where that is? My capri is in the shop right now getting it's control arm fixed so i can't look under the hood rn
