Author Topic: Fan always on  (Read 3031 times)
Stickshifter6
    • 1993 Capri 5 Speed 1994 Capri 5 Speed
Fan always on
« on: May 27, 2018, 10:55:08 AM »
My radiator fan is always running. The only thing I can think of is I replaced the sensor with a used one from a parts car, could this be bad?
here's a picture of the sensor I replaced
http://shop.moderncapriparts.biz/Catalog/ProductDisplay.cfm?id=14613&cid=148
Re: Fan always on
« Reply #1 on: May 27, 2018, 11:58:28 AM »
Usually, this is caused by a bad ground from the harness to the top of the thermostat ground that is transferred through the bolts securing the thermostat. Create another ground from the thermostat housing to the block or another ground and it should stop.
pilotlars
    • 1993 Mercury Capri
Re: Fan always on
« Reply #2 on: May 27, 2018, 02:34:49 PM »
My 1992 Mazda 323 had the same issue with the AC fan. The only way to shut it off was to remove the relay. it would run with the engine off and key removed. Since the car's AC didn't work anyways and I was going to spend 100s bringing it up to R132a spec I just went without it. That probably doesn't help you though.
Re: Fan always on
« Reply #3 on: May 27, 2018, 04:51:17 PM »
The sensor could be bad, the ground could be poor.
If you have removed the AC system and the AC harness, you will need to jumper the harness plug on the firewall for the fan to return to normal function
Stickshifter6
Re: Fan always on
« Reply #4 on: June 03, 2018, 11:08:56 PM »
I ordered a new temperature sensor and it fixed the issue! For anyone needing one of these, rockauto has them for $10. They are $30 and up everywhere else I looked.
It the Airtex Wells part #1t1120
https://www.rockauto.com/en/catalog/mercury,1993,capri,1.6l+l4,1196670,cooling+system,temperature+sender+/+sensor,4748
« Last Edit: June 03, 2018, 11:10:47 PM by Stickshifter6 »
