Author Topic: Bronze shifter bushings  (Read 19789 times)
belleaudb
    • 92 XR2
« on: April 30, 2018, 06:16:25 PM »
10 years ago I replaced the shifter bushings at the lever and transmission with bronze ones.
However I did not replace the bushings on the U-joint that is held together with a peened stud.
Today chasing a shifter buzz I found this:
The nylon bushings were totally gone.
So I used an angle grinder to grind away the peened end of the stud holding the joint together:
Went to the store and purchased a 10mm bolt and self locking nut. 2 of these bushings:
I had to shorten one bushing about 12mm. Then I used a 11/32 drill to slightly enlarge the inner diameter of the bushings to allow the 10mm bolt to fit.  I also drilled out the smaller hole on the U-joint to allow the 10mm bolt to fit since I did not have a shoulder bolt.
Pressed in the bushings and then packed with high temperature wheel bearing grease and grease all bushing surfaces.
Reassemble the u-joint and tighten the bolt and self locking nut to remove all slack in the joint, but allow freedom of movement.
Make sure the threads of the bolt used face the passenger side of the car. If they are allowed the face the driver side, the bolt will hit the lower engine cradle and you will not be able to shift into 1st or 2nd gear. I found this out AFTER reassembling everything, getting cleaned up and preparing for a test drive.
Now all the bushings in the shifter linkage are bronze and will last much longer and handle heat better than the original Nylon ones.
Here is a picture of the final assembly before I gave it a good cleaning.
« Last Edit: October 01, 2020, 12:31:52 PM by belleaudb »
Re: Bronze shifter bushings
« Reply #1 on: May 01, 2018, 10:04:54 AM »
Nice write-up.
JimmyGermany
    • 1993 Capri non-turbo
« Reply #2 on: September 27, 2020, 03:27:30 PM »
Hi all!
Looking to do the same job.
Apologies for my imperial (SAE) ignorance, but really 11/32 to embiggen the bushing?
That’s less than the 10mm required.
Maybe 13/32? (10.319mm)
Cheers
James
JimmyGermany
« Reply #3 on: September 27, 2020, 03:46:50 PM »
...  not trying to be a know-it-all (I know so very little)
But I need to order anything in SAE dimensions.
Good thing my wife is going to Canada soon - need someone to pick up the stuff I‘ve bought
James
« Reply #4 on: September 29, 2020, 08:45:53 AM »
Bronze bushings are available in metric, no need to drill.
JimmyGermany
« Reply #5 on: October 04, 2020, 04:06:54 PM »
Well, I ordered and have the CorkSport ones and they need embiggening.
Got my mitts on a 13/32 drill, and will try my luck tomorrow.
Cheers!
James
JimmyGermany
« Reply #6 on: January 16, 2021, 05:54:29 AM »
Gentlemen!
Just got the "new" shifter linkage installed, with the bronze bushings.
A world of difference. The movements are much shorter and very little slop.
Cheers
James
« Reply #7 on: January 16, 2021, 09:23:12 AM »
Now you need to lengthen the shifter rod about 18mm to create a short shifter.
9193CapriXR2
« Reply #8 on: September 17, 2023, 05:24:33 PM »
i know this is a 2 year old thread..but Ive replaced the shifter bushing with the nylon ones I purchased from Napa Auto Parts and still have considerable slop in the shifter.  I would love to do this bronze bushing upgrade.  How many of the 882992 flange bearings are needed?  Is it just the one for that bolt sleeve and if so where can I get the bronze bushings to replace the nylon ones?  The bolt used was a 10mm x ?  Thanks!
« Reply #9 on: September 19, 2023, 01:54:47 PM »
Did you replace the bushings in all three places?
9193CapriXR2
« Reply #10 on: September 19, 2023, 02:46:34 PM »
I only saw 4 replaceable bushings.  I've read there are 6 but I did not see where the other 2 went.  There were no bushings left at all.
« Reply #11 on: September 19, 2023, 09:22:57 PM »
There is one set that is riveted in, I believe pictured in the top of the thread here. The rivet must be ground/drilled out and replaced with a bolt. Replacing the last 2 of the 6 bushings should tighten your shifter up
« Reply #12 on: September 20, 2023, 08:02:02 AM »
Yup, you can get the bolt and bushing from Will Samet at Samet Enterprises.
9193CapriXR2
« Reply #13 on: September 20, 2023, 11:08:28 AM »
I googled Samet enterprises and it didn't come up with anything?
« Reply #14 on: September 21, 2023, 08:42:01 AM »
Go to FaceBook, he's active in the Festiva and the Capri communities.
