Author Topic: How do u test the icm on a 92 mercury capri  (Read 8451 times)
Teamreedracing
    • 92 capri 06 trailblazer 94 s10 03 honda 00 gmc
« on: November 25, 2017, 06:45:09 PM »
Does anyone know how to test the icm I'm still not getting spark after replacing the whole wiring harness
Re: How do u test the icm on a 92 mercury capri
« Reply #1 on: November 26, 2017, 12:53:22 AM »
The spark signal is generated in the distributor. Most often this is a failure of the ignitor in the distributor.
Have you tested for tach signal? (crank the engine, does the tach needle bounce?)
Teamreedracing
« Reply #2 on: November 26, 2017, 01:34:21 AM »
The tach don't move at all
NiteLord
    • 91Cap,94Cap,86FieroGT,94G.C
« Reply #3 on: November 26, 2017, 10:53:57 AM »
..Had same problem just last week..(Code 01 when you pull your trouble codes)..mine turned out to be the ignition module in the Distributor...very costly at Auto Parts store..around $220 for the module or $250 for a rebuilt Distributor...get on EBay there's a guy selling Cardone Rebuilt Distributors(dual vacuum) still in the box for $25...
« Last Edit: November 26, 2017, 11:16:06 AM by NiteLord »
Teamreedracing
« Reply #4 on: November 26, 2017, 11:50:44 AM »
Was just looking at the 25$ distributor last night and i just ordered it how do u pull the codes
« Last Edit: November 26, 2017, 12:20:44 PM by Teamreedracing »
NiteLord
« Reply #5 on: November 26, 2017, 12:23:41 PM »
..passenger side in Engine bay on firewall you will find 3 connecters..1 Large green..1 Large yellow and "1 Small Green"...take a wire and place it into the SMALL Green Connector and ground it...turn key ON but DO NOT start the car..watch the check engine light it will go off than start blinking in dashes the stored codes to you..copy the codes down then go to the "search" on this page and write in "ECM CODES"..there you will find the meaning of the codes..
Teamreedracing
« Reply #6 on: November 26, 2017, 01:05:29 PM »
Thank you nitelord as soon as I run into town I will check it
NiteLord
« Reply #7 on: November 26, 2017, 01:08:57 PM »
...ENSURE that you do not have the Turbo...the distributors are different from non-turbo and turbo engines...
Teamreedracing
« Reply #8 on: November 26, 2017, 01:12:06 PM »
No its a N/A capri I wish it was turbocharged
Pappy T
    • 91 base Capri
« Reply #9 on: November 26, 2017, 04:37:41 PM »
Having been through this situation myself, I went to autozone for the igniter, got a warranty with it..don't remember if 1 year or lifetime .
That said , I should have done that from the beginning, had 4 or 5 Cardone dist thru (?, I'll think of it ) and all did the same thing, puked out in no time, made almost 9 months on 1 of them . Last time they just refunded my $ and called it a day. Cardone had some Really cheap igniters, 2 had a made in Hong Kong sticker on them . My experience anyhow . Good luck with it .
NiteLord
« Reply #10 on: November 26, 2017, 11:32:33 PM »
...Well that's certainly interesting Pappy..my 91 didn't have a distributor when I got it 11 years ago..got a Cardone Rebuilt at Advance and 27,000+ miles later it's still going strong...knock on wood...LoL..LoL..
Pappy T
    • 91 base Capri
« Reply #11 on: November 27, 2017, 09:01:56 AM »
Yeah, 11 years ago ! I'd like to know when they went with cheapened parts . Shoot, 11 years ago I was in better shape, haven't found a rebuild kit for me tho and would be leery if I did...foreign parts ya know  :P  Now to track down my 3500 rpm stutter, haven't gotten close to that yet...
Keep your eyes on the road folks , be safe
NiteLord
« Reply #12 on: November 30, 2017, 03:04:40 PM »
..well I got my two Cardone Rebuilt Distributors that a paid $25 a piece for..matched them up to the Cardone Rebuilt Distributor that I bought 11 years ago for my 91 and everything matches up including the numbers on the Ignition Module...nothing says Made in Hong Kong...put a New Rebuilt in the 94 and she fired right up...YES..!!!!...
Pappy T
    • 91 base Capri
« Reply #13 on: November 30, 2017, 08:47:51 PM »
Man, don't you wish everything went that easy and well ?!
Teamreedracing
« Reply #14 on: December 01, 2017, 08:15:35 PM »
I hope mine goes that well
