Author Topic: help a newbie!!!  (Read 2460 times)
WVFish
    • 93 Capri (just arrived)
help a newbie!!!
« on: August 13, 2017, 11:04:29 PM »
Recently acquired a 93 Capri with 85,000 miles and in incredible original condition. Very impressed so far. Replaced Both axle shafts, a dragging brake caliper, and some maintenance, and then 2nd drive driver side window regulator goes kaput! No big deal had old cars before, well you know the rest of the story so I found you all. I printed the rebuild instructions so generously shared, cables, stops, bolts, and JB weld I'm figuring good to go. tested it prior to remounting , All Good!! So now its back together and first time window goes in full down position the cables derail. The Pulley was pretty screwed up, dressed it up as much as possible. groove seemed to deep?? Help we have vacation coming fast and a convertible is the only way to do the beach. I'd like to source a new or properly rebuilt Drivers side window reg. my motor seems fine. Thanks in advance. Bill Fisher
Re: help a newbie!!!
« Reply #1 on: August 14, 2017, 10:50:08 AM »
I give 5*s to James Whitt, he's on here  and you can also get him on FB.  He is fast and stands behind his work.  There is a wrecking yard in eastern WV that had three last year, but I can't find the info.  I'll keep looking.
WVFish
« Reply #2 on: August 14, 2017, 09:19:35 PM »
Many thanks I'm in Parkersburg, WV. if you think of it that would be to easy.
Any loose pulleys out there?
James Whitt? Found James White
« Reply #3 on: August 15, 2017, 08:35:12 PM »
It's James Whitt in Opp, Alabama.  He's on the forum and on FB.
The salvage place is D and D in Wardensville, WV.
WVFish
« Reply #4 on: August 17, 2017, 09:08:00 PM »
Thanks! I Trout fish around Wardensville.
