Author Topic: Oil pan leak issue  (Read 1936 times)
Snigalfriz
    • 1991 NA Capri
Oil pan leak issue
« on: June 26, 2017, 04:38:29 PM »
Folks,
I have a 92 NA that has an leak at the oil pan gasket.  I have tried new gaskets and with and without black rtv.  I have tried just black rtv and still it doesn't seal up good.  I have a 91 NA as well that I used just black rtv and it worked fine.
Anyone run into similar issue?  I am tempted to try another oil pan, but not sure if an old miata oil pan will work.
Any suggestions?
1991 Mercury Capri 5-sp
1992 Mercury Capri 5-sp swap
1999 Ford Contour SE 24v v6
2003 Lincoln LS
2007 Saturn Outlook XE AWD
2014 Chevy Cruze LT
