Author Topic: Car starts then dies, Then starts up. Help  (Read 2177 times)
T Rex
    • 1993 Capri N/A. 1995 Rover Mini. 2011 TDI Jetta
« on: June 11, 2017, 12:48:17 PM »
'93 N/A car. Worse when cool temp out. In the morning I start it and it goes to 1,500rpm then runs a few seconds dies then starts right back up. Will do this 3 or 4 times then runs fine when warmed up.
New plugs, wires, cap, rotor, mass air meter.
I pulled off the Idle control valve to test. The ohms tested fine and when I warmed it with a hair dryer it shut off flow through the air hoses. The only thing odd was that it didn't flow really freely when cold. Should that flow freely? That's what I was thinking was a possible issue, since the car runs and idles great when warmed up. Thanks for any help, I'm about to let it get 100 degrees out and sell it.
Snigalfriz
    • 1991 NA Capri
Re: Car starts then dies, Then starts up. Help
« Reply #1 on: June 26, 2017, 05:54:24 PM »
T Rex,
Check you ignition coil.  My did something very similar, then died and won't restart.  I swapped the coil from my other one and it fired up and ran fine.
So I got a new coil and the problem has completely gone away.
1991 Mercury Capri 5-sp
1992 Mercury Capri 5-sp swap
1999 Ford Contour SE 24v v6
2003 Lincoln LS
2007 Saturn Outlook XE AWD
2014 Chevy Cruze LT
