Author Topic: New here. Radiator question.  (Read 1730 times)
Jsprudhom
    • Crown vic. Cx5. Capri.
« on: March 24, 2017, 11:06:51 AM »
Good morning everyone. I searched for the answer to my question, but there seemed to be some confusion.
I'm trying to go pick up a Capri that's 13 or so hours away. trouble is, it got run up under a Ford Escape. Damage is all body and radiator. Broke the radiator right below the filler neck.  I'm going to try to epoxy it to get it a couple hours down the road, where I can replace it if I need to.
If needed, has anyone determined what the correct part number for an xr2 replacement is? I saw a couple threads where guys were getting radiators that were too wide. Don't want to be dealing with that a long way from home.
Also, on replacing it. Do the turbo models have transmission cooling lines that run out of the radiator to deal with also? Anything else I may want to consider?
 I can't post pictures that aren't posted to the internet, apparently, so I can't show you the actual damage to the radiator. If someone wants to middleman me, I'm happy to send it.
Thanks y'all.
