Author Topic: no instrument lights or tail lights  (Read 2993 times)
Skip13
    • 91 Capri
« on: February 15, 2017, 06:09:15 PM »
Checkd all fuse and they are good
Re: no instrument lights or tail lights
« Reply #1 on: February 15, 2017, 07:32:40 PM »
Put the light dimmer all the way up then turn on the headlights, it should work then.
« Reply #2 on: February 15, 2017, 11:44:06 PM »
Do the headlights come on okay? No tailights is a weird issue
« Reply #3 on: February 16, 2017, 01:48:51 AM »
Do the brake lights work when you push the brake pedal and do the headlights work when you turn them on?
If yes to both, then the problem will most likely is the headlight switch.
The headlight switch has two sets of contacts. One set is for the dash, park, and tail lights. The other set is for the headlights.
Skip13
    • 91 Capri
« Reply #4 on: February 16, 2017, 08:24:38 AM »
I will try all the posts thanks
garlson
    • Capri
« Reply #5 on: March 23, 2017, 08:33:17 AM »
Try taking out the fuse box and clean all the contacts.
