Author Topic: WTB 1991 Capri headlight switch  (Read 2790 times)
1991MCapri
    • Capri
« on: June 25, 2016, 04:42:10 PM »
Hi all,
My bright headlights do not work, and neither does the flash to pass. The low beams work fine. I have it narrowed down I believe to the dash mounted headlight switch by the manual. Does anyone know where or if one is available?
Thanks.
Jim
Re: WTB 1991 Capri headlight switch
« Reply #1 on: June 25, 2016, 04:54:43 PM »
If your low beams still work, then the headlight/park light dash switch is working just fine.
Sounds like the turn signal/highbeam switch assembly went bad and they are readily available at most auto part stores.
« Reply #2 on: June 25, 2016, 05:20:55 PM »
I'm in agreement with Chrispoe....Sounds like your multi-switch.
Let me know if you need one - I usually keep brand new ones in stock.
1991MCapri
    • Capri
« Reply #3 on: June 25, 2016, 08:05:57 PM »
Thanks guys, I will replace the malfunction switch then. Russ I will check the local auto parts store to see if they have one. If they don't I will let you know. Again thanks guys.
1991MCapri
    • Capri
« Reply #4 on: June 30, 2016, 11:22:35 AM »
Ok, I have replaced the multifunction switch in the steering column. My flash to to pass now raises the headlights but I still do not have any brights. Any ideas?
