Author Topic: 1993 Capri won't start  (Read 3002 times)
Quietwyatt
    • 1993 Mercury Capri xr2 n/a
« on: March 14, 2016, 09:29:25 AM »
I know this seems like a common problem to start things that are new
Plugs wire distributor cap and rotar pickup coil ignition coil starter battery alternators and belts clutch master cylinder and slave cylinder maf I rewired the wired that had corroded by the way that's all the connectors it has all new ground  wires and power wires
The car ran fine until I put the clutch master cylinder on the it started I drove around the block parked it and it was pour coolant from the overflow the car never started again
Now that that's there there is blue spark to all four plugs also the compression is spot on the plugs have fuel on them its pops like it's trying to start but won't do so any help would be much apriciated
« Last Edit: March 14, 2016, 09:33:14 AM by Quietwyatt »
Re: 1993 Capri won't start
« Reply #1 on: March 14, 2016, 12:38:18 PM »
Vacuum issue maybe. Check booster line and PCV.
« Reply #2 on: March 16, 2016, 04:57:35 AM »
Old gas? Does she start using starting fluid?
