Author Topic: New clutch project for summer  (Read 2236 times)
94daves
    • 1994 Mercury Capri N/A
« on: March 09, 2016, 09:00:10 PM »
I have a 94 NA with 99k miles and want to replace the clutch and other clutch related items this summer.  To purchase everything I need from RockAuto, what should I buy?  Here's the start of my list:
1. Exedy clutch kit
2. Centric clutch master cylinder
3. Centric clutch slave cylinder
4. ??
Re: New clutch project for summer
« Reply #1 on: March 10, 2016, 12:38:41 AM »
Rear main seal
Axle seals if you're motivated
Engine mounts if they're shot
Since you will likely have the suspension apart to get the axles out, it's a good opportunity to do balljoints / tie rod ends / control arm bushings / swaybar endlinks / struts / wheel bearings & rotors if need be
