April 28, 2024, 08:59:58 AM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Tech, Repairs, Upgrades
Brakes/Suspension/Tires/Wheels
Drumming noise when driving
« previous
next »
Pages: [
1
Print
Author
Topic: Drumming noise when driving (Read 5446 times)
Casper
Jr. Member
93 XR2 and 91 Turbo Clubsprint (tribute)
on:
February 13, 2016, 06:48:10 PM »
Hi All,
I cant find anything that seems similar to this issue. My 93 N/A manual just started making a low resonance drumming noise when driving - it sounds like it is coming from the front right wheel (driver side in OZ) and has a slight vibration with it. It occurs when driving at speed (60km/h for instance) and speeds up when applying the brakes. It stops when vehicle is stopped.
I know my front struts are on the way out (a bit sloppy) but not sure if a suspension item or is it a CV joint?
I have only heard it with car fully loaded (2 adults and 2 children) - not sure yet if it occurs with just driver in vehicle.
Any thoughts or similar issues from anyone?
Thanks
Paul
Sr. Member
91 BP Capri GT
Re: Drumming noise when driving
Reply #1 on:
February 13, 2016, 07:27:44 PM »
Might be a wheel bearing starting to fail.
Sr. Member
Do no harm, take no sh!t.
92 XR2, 01 LL Bean Outback, 92 Concours, 86 F150
Reply #2 on:
February 14, 2016, 12:37:46 AM »
...drumming? Like a definitive, percussive sound? Do you feel it through the steering wheel? Check your brakes for anything out of place, and if they've gone past the minimum thickness, replace them.
Administrator
Old-Timer
91 BPT AWD Capri & 1991 XR2
Reply #3 on:
February 14, 2016, 10:32:20 AM »
Could be a wheel bearing, or a bad tire / broken belt in the tire
Sr. Member
Reply #4 on:
February 14, 2016, 10:39:09 AM »
Mmhmm. If you have access to a tire balancer that can force match the tire, that would be helpful.
batterydoctorsrl
Newbie
91 Capri Base
Reply #5 on:
March 30, 2016, 11:10:17 PM »
busted strut mounts will make that noise.
Casper
Jr. Member
Reply #6 on:
April 01, 2016, 07:07:06 AM »
HI All,
thanks for the info provided - it seems the noise has stopped with the only difference being air pressure in tyres. I do have a broken strut mount bearing (very clunky at times) and it may be linked to this - I will be replacing struts soon (and mount) so hopefully that may be the issue.
Thanks again.
Paul
Casper
Jr. Member
Reply #7 on:
November 27, 2016, 11:05:00 PM »
Its been some time with this one but mystery noise was a worn driveshaft - had it replaced and no no noise....!! Remember that one for next time.
Administrator
Old-Timer
Reply #8 on:
November 28, 2016, 11:28:58 AM »
Thanks for the update!
garlson
Newbie
Capri
Reply #9 on:
March 28, 2017, 06:30:30 AM »
My car is having a weird noise. Will definitely check the driveshaft since my wheel bearings are in good condition.
Print
Pages: [
1
« previous
next »
