Author Topic: 91 N/A 5 Speed FS  (Read 2681 times)
BlewitUp
91 N/A 5 Speed FS
« on: November 02, 2014, 05:27:48 PM »
I am recently got a job that requires me to have a, "presentable" car.  My Capri doesn't exactly fit the bill for customer meetings apparently.
91 NA 5 Speed
The bad:
-Leaking Fuel Tank
-Bondo Bucket
-Kind of rusty.  Holes in the floor under the carpet
-The dash has a lot of the trim removed (have all the pieces)
-Driver's seat has rusted apart from the floor in one of the four mounts and the material is torn in many spots
-Passenger side window switch won't roll the window down
-Trans can stick in 5th gear if you try to pull it out too slow
-Shifter linkage bushings are nonexistent
-Timing belt hasn't been replaced in well over 100K miles
-Car has ~195,000 on it
-Need a screw driver to get heat
-Blower resistor is shot
-Has a small valve tick that mostly goes away when warm
-Windshield has a pretty decent crack in it
The good?
-Has a hard top
-Has a new soft top and the handles aren't broken on the frame
-new battery
-New brakes and wheel bearings all the way around
-New master cylinder
-New clutch slave cylinder
-New valve cover gasket and O rings
-New new plugs and wires
-Newer starter
-Newer fuel pump
-Newer tires
-Head light motors work
-All light housings are in good condition
-Comes with a lot of spare parts.  Some hard to find ones like driver's door handle and glovebox latch.
I would expect someone to buy this as a parts car probably.  Given the two tops, rims, and tires...  Those could be parted out for about $600.  I'm asking $750 but willing to hear offers.  Remember, it does still run, drive, and stop well.
Local pick up only.  I'm in the Flint Michigan area.  48439 to be more specific.
BlewitUp
Re: 91 N/A 5 Speed FS
« Reply #1 on: February 09, 2015, 03:58:24 PM »
If you are interested in parts off this car, please email me.  It will be going to the JY in 2 weeks.  Pick up only.
r pos ler "At" google mail dot com.
No resonable price will be turned down.  I would be happy to see it get used instead of crushed.
« Reply #2 on: February 09, 2015, 05:37:12 PM »
Looks better than mine did. small rust holes on the sides are now huge rust holes. :(
