Pages: 1 ... 34 35 [36]
Author Topic: What did you do to your Capri today?  (Read 242420 times)
« Reply #525 on: January 01, 2022, 06:36:59 PM »
Got to ride around with the top down again today.  My fourth last ride of the year.....lol  10 miles short of 200K in my '92 XR2.
« Reply #526 on: June 13, 2022, 10:55:43 AM »
Found out my black XR2 is actually charcoal metalic.
JimmyGermany
    • 1993 Capri non-turbo
« Reply #527 on: September 07, 2022, 03:48:39 PM »
Gentlemen! And ladies!
Long time no see!
I’ve had my Capri out a lot this season. Passed the dreaded TÜV (biennial inspection) and is good to go until 2024, when I’ll get the historic plates.
Tracking a problem which illuminates the “Check Engine” light after reaching operating temperature. Stays on. Engine Starts, rund, and reacts normally to throttle. The O2 sensor was replaced before the inspection, so that’s my prime suspect.
Greetings again from Germany. Good to be back!
« Reply #528 on: May 16, 2023, 09:59:15 AM »
Finally got the Capri from Duluth!
Drove three hours with a sketchy, spare, and no charging system. Then, when I finally got it up in the air, I found out I had two broken coil springs on the front. So I ordered some H&R lowering springs, put those in the front along with new KYB struts and House brand strut mounts.
Now, I’ve got to do front rotors, calipers, pads, rear sway bar links, replace the coil springs in the rear maybe, put in the new three row racing radiator. Besides the Falken Azenis awaiting installation, that’s about it for now.
« Reply #529 on: May 17, 2023, 08:40:16 AM »
COOL
jdp
« Reply #530 on: May 26, 2023, 09:53:49 PM »
94xr2 is up on blocks.  redoing half axles, struts, new springs, ball joints, tie rod ends, new brake flex lines, etc.   When I get this one done, I move onto my wifes 94NA to do the same thing.
John
« Reply #531 on: May 27, 2023, 08:18:38 AM »
WOW.....that is some project. Wish you luck with it, hopefully you can be back on the road again.
jdp
« Reply #532 on: May 27, 2023, 02:13:39 PM »
I've been putting it off......sigh!
John
