Pages: 1 ... 25 26 [27] 28 29 ... 36
Author Topic: What did you do to your Capri today?  (Read 233587 times)
« Reply #390 on: May 16, 2019, 02:55:06 PM »
belleaudb, those look nice.  Good job.
« Reply #391 on: May 22, 2019, 01:54:43 PM »
Got lucky at Pull-A-Part in Charlotte, NC.  Instrument panel, turbo and ECU and some other stuff.  The car has a  hardtop that has been painted flat black but is in good condition.  Please tell me a 93 ECU is the same as 91/92!
« Last Edit: May 22, 2019, 01:57:03 PM by greywolf27030 »
« Reply #392 on: May 22, 2019, 07:24:53 PM »
It is indeed the same ECU
jdp
« Reply #393 on: May 22, 2019, 09:36:45 PM »
Nice score Jack!
John
« Reply #394 on: May 23, 2019, 09:37:02 AM »
Great and the turbo bearings are tight, although one of the blade tips is slightly bent.
Thanks, Jack Byrd
« Reply #395 on: May 25, 2019, 08:33:05 PM »
Went to the monthly cruise in at Elkin, NC. They were having a special event for Miatas.  I talked to a lot of the owners and members of the Carolina Miata Club.  Got a lot of interest and several compliments.  I was never able to get up with the president, but talked to several members and they said it should be possible for us to tag along at their events and they are very active with touring and shows.
Skunkwrkz
« Reply #396 on: June 03, 2019, 06:40:08 PM »
- Installed 3 Row aluminum radiator
- Installed 323 GTX Silicon Rad Hoses
- Installed A/C delete kit
-Removed A/Compressor and hard lines to mothball for later
« Reply #397 on: June 04, 2019, 05:46:23 PM »
Nice, trimming that thing down.
Skunkwrkz
« Reply #398 on: June 04, 2019, 06:26:49 PM »
Yeah. It all worked out well except for my oil filter sandwich. It leaked like a sieve. I need a better option for my external ProSport Oil Pressure gauge.
« Reply #399 on: June 05, 2019, 06:24:11 PM »
Are those blue hoses silicone?  Last forever?
Skunkwrkz
« Reply #400 on: June 05, 2019, 10:33:32 PM »
Yessir.....Those hoses, cockroaches and Twinkies will be the only thing to survive nuclear Armageddon... 8)
Skunkwrkz
« Reply #401 on: June 05, 2019, 10:36:44 PM »
Pics of the top hose and the temp sender.
jdp
« Reply #402 on: June 06, 2019, 09:56:50 PM »
Is that a temperature sensor in the top hose?
John
Skunkwrkz
« Reply #403 on: June 07, 2019, 01:24:12 AM »
Yes it is. It's for a digital ProSport gauge.
Skunkwrkz
« Reply #404 on: June 17, 2019, 08:56:32 PM »
Some more new hoses that actually are from a silicon set of hoses I bought for the long heater hose in the back of the block. These were extra and just happen to be exactly what was needed to replace more old rubber hoses that are starting to go. Also in the pics is a new (discreet) BOV I have been itching to install. The diaphragm on my stock DV was gone long ago. I like it.
« Last Edit: June 17, 2019, 08:59:30 PM by Skunkwrkz »
