Pages: 1 ... 11 12 [13] 14 15 ... 36
Author Topic: What did you do to your Capri today?  (Read 233560 times)
« Reply #180 on: September 26, 2015, 01:02:26 PM »
Thanks guys! Hey Pappy, try to post a pic of your cover. I'd like to see it too. Gives other owners some ideas on different looks.
94daves
    • 1994 Mercury Capri N/A
« Reply #181 on: September 27, 2015, 02:23:12 PM »
I replaced my tires and wheels.  I went with P205/45 R16 BFGoodrich G-Force Sport Comp-2 tires and American Racing AR95 Estrella wheels, both from Tirerack.  I had them mounted and balanced before they were shipped.  They came with new lug nuts and centering rings.  Easy to install.  I have the 1994 NA wheels and tires up for sale if anyone is close to The Palace of Auburn Hills and wants some winter wheels.  I also have the KYB struts and lowering springs on the car.  I think the profile finally looks good!
Here are before and after pictures.
« Reply #182 on: September 27, 2015, 03:14:36 PM »
Ooh, that looks really good! I really like the way lowering looks as well, but I personally don't want to lower mine since I drive mine year round, in some pretty good lake effect snow.
However, I bet the handling is way better with the stiffer springs, which I wouldn't mind improving as well.
Chrome wheels look so good on a red car! I hope you don't get them near salt though,  chrome just pits so bad. I hung on to the 94 N/A alloys I pulled from the car I scrapped just for snow tires.
Anyway, thanks for posting, it's nice to see all the other Capris, and yours is beautiful.
94daves
« Reply #183 on: September 27, 2015, 05:14:37 PM »
Thank you.  Yes, the handling feels great.  The tire/wheel upgrade really improved the feel.  When I lowered it last summer, I felt as if the front would bounce a lot over certain bumps, almost like it was a phase/resonance thing.  Since I put on the new tires and wheels, it has gone away.  The car feels very solid.  I don't drive it in the winter so I don't have to worry about salt on the wheels.
Kudos to you for driving your car year round and keeping it looking so good!
Pappy T
    • 91 base Capri
« Reply #184 on: September 28, 2015, 08:37:31 PM »
Hi SHOwn, I'll look into as to how to post pics on here, been laid up for 2 weeks now, not in the mood for brain work !! Pictures are worth a thousand words,....there are exceptions though I guess   ;)
« Reply #185 on: September 28, 2015, 10:51:12 PM »
Hey Pappy, As far as posting pix goes, it isn't as easy as one would like, but not to hard if you have another image hosting account like photobucket. I used my snapfish account (where I usually store pix for sending to the local drugstore for printing) all you have to do is highlight a picture there, and right click on it and get the URL into your clipboard (copy) then switch to TeamCapri and pick the left button, 2nd row and paste where the cursor is (between the brackets). That's how you can post a pic.
Anyway, hope you feel better soon.
Ron
« Reply #186 on: December 18, 2015, 09:03:34 AM »
Disassembled the cooling system a piece at a time and flushed or drilled out everything that had been stopped up by the PO using who knows how much radiator sealant.  This is the first time it's idled properly since I bought it.  Well, at least the IAC is working, idle still got to be worked on.
« Reply #187 on: December 28, 2015, 06:46:21 PM »
Broke my exterior driver's side door handle.  As if that wasn't bad enough, it's going to be raining the next three days.  How much trouble is it to replace it?  I've already been inside the door and replaced the power window motor.
« Reply #188 on: December 28, 2015, 11:13:00 PM »
If you had the door apart before, it's not much harder. Take the interior panels off, and use a 10mm socket ( 1/4"drive is best) on the front and back of the handle. Then there are two plastic clips, if my memory is correct. After all is detached, it is a little tricky to twist the assembly the rest of the way out. Getting the actuator rod clip back on is the hardest job. I have no further tips on it just persevere.
HTH,
Ron
« Reply #189 on: December 29, 2015, 11:12:56 AM »
HTH,
Ron
Thanks, when I do a job like that, I wish I had smaller hands.
Jack
« Reply #190 on: December 30, 2015, 12:40:59 AM »
HTH,
Ron
Jack
A really good flashlight helps this job a lot!
Merlin
    • 91 Capri N/A, 93 XR2, 2018 Jeep Renegade
« Reply #191 on: January 14, 2016, 10:02:18 PM »
The past 2 weekends I have replaced the cooling system and the front suspension. The cooling system I replaced the radiator with an all aluminum, replaced all the hoses, and the thermostat.  I replaced the water pump and front freeze plugs a few months back.  The front suspension I replaced the front rotors and bearings, front struts, cv axles, ball joints, and control arm bushings.  Drives much better now. Would like to install front and rear sway bars and a strut tower brace.
rsharry
    • Capri and Capri XR2
« Reply #192 on: January 29, 2016, 09:23:43 AM »
Engine of my womans capri
« Last Edit: January 29, 2016, 11:37:49 AM by rsharry »
Snigalfriz
    • 1991 NA Capri
« Reply #193 on: March 08, 2016, 12:29:09 AM »
I added a spoiler from a 2004 Ford Mustang (RS357).
1991 Mercury Capri 5-sp
1992 Mercury Capri 5-sp swap
1999 Ford Contour SE 24v v6
2003 Lincoln LS
2007 Saturn Outlook XE AWD
2014 Chevy Cruze LT
« Reply #194 on: March 08, 2016, 12:33:12 AM »
Any pics? Sounds cool.
