Author Topic: 1990 turbo Capri  (Read 8892 times)
Monza Red
    • 1990 Capri turbo
1990 turbo Capri
« on: September 26, 2014, 09:44:19 PM »
Hi all,
Another Newbie here, details of my Capri as follows -
Have owned the Capri for about 5 years now, initially brought it for my partner as her VW Polo was becoming very unreliable. The Capri had 250000 KM when I got it and it has been very reliable, the VW only had 110000KM on it and was falling apart, whats that tell you ? Only did a timing belt, seals and fluid change when purchased and topped up the Air con gas, nothing else was needed.
Have recently rebuilt the B6T, blueprinted, fitted hypereutectic pistons, H beam rods and cleaned up the ports a bit but the biggest change has been the fitment of Garrett's smallest ball bearing turbo - GT2554R on a custom exhaust manifold by Abe Tech (a work of art).
Was a challenge to get the manifold angle turned in towards the engine enough to clear the radiator. Also fitted a large PWR front mount intercooler.
Only running an air flow meter and standad injectors and ECU at present so haven't really been giving it full revs, worried about it leaning out up top.
Hoping Rocketman can help me out with a rocketchip to suit otherwise will need to fit an after market ECU and have it set up on a dyno accordingly.
Body wise have fitted a fiberglass clubsprint style rear bumper and Capote top, currently working on the front bumper.
Have limited photos at present, will add more in due course.
Cheers
http://imgur.com/a/beWeB
« Last Edit: September 27, 2014, 03:35:38 AM by Monza Red »
DarkAngel
    • Build Thread
Re: 1990 turbo Capri
« Reply #1 on: October 15, 2016, 12:45:01 PM »
Those look like 18 inch rims !
Current Project XR2 SE
To Do
tracker gps, respray
Monza Red
    • 1990 Capri turbo
« Reply #2 on: October 15, 2016, 06:48:28 PM »
Only 17's they are a very tight fit, the rear tyres  just touch the top of the shock mounts. Would consider fitting 16's but cant find the offset and style i like.
What rims are you running ?
DarkAngel
    • Build Thread
« Reply #3 on: October 15, 2016, 07:01:27 PM »
Picking up some BBS 16x7 +40 rims on wednesday, and going with Michelin pilot sport 3 205 45 16
check out my build thread
To Do
Monza Red
    • 1990 Capri turbo
« Reply #4 on: October 15, 2016, 07:15:39 PM »
Let me know how they fit under the guards. Forgot to mention i also had to roll the rear guards to fit the tyres under the guards.
DarkAngel
    • Build Thread
« Reply #5 on: October 15, 2016, 07:22:04 PM »
According to Rocketman... the biggest tyres on 17x7 rims to fit without mods are 205 40 17 and thats at +40 offset.
Therefore the biggest tyres on 16x7 rims to fit as is are 205 45 16 at +40 offset rims.
Btw: my friend used the 16x7 205 45 16 fitment on her clubsprint with no issues
« Last Edit: October 15, 2016, 07:24:17 PM by DarkAngel »
To Do
Monza Red
    • 1990 Capri turbo
« Reply #6 on: October 15, 2016, 08:04:06 PM »
Thats good to know, look forward to seeing photos of your new rims fitted.
