Author Topic: 30 MPG?  (Read 4223 times)
30 MPG?
« on: July 17, 2014, 07:31:51 PM »
Finally ran though my first tank of gas and got 30MPG.  Is this the common mileage for these cars?
Thanks, Jack Byrd
Re: 30 MPG?
« Reply #1 on: July 17, 2014, 09:30:30 PM »
I get about 32 on the highway with my 93 xr2, on 205/50/15's on stock 3 spoke rims which effectively lowers the gear ratio a little for better mpg, 70 mph and below.  The red 91 xr2 my daughter drives gets no better than 27 mpg... Chris
hustlertsi
    • 1991 mercury capri xr2
Re: 30 MPG?
« Reply #2 on: July 18, 2014, 10:41:28 AM »
I just bought a 1991 xr2 and I seem to be getting just under 25mpg
Re: 30 MPG?
« Reply #3 on: July 18, 2014, 01:59:36 PM »
Should be getting around 30 sometimes more on the highway. XR2's depends on stock/modified and how it's driven.
If your MPG's are low a tune up is in order. Air filter, O2 sensor, plugs/wires, cap/rotor, check your tires, alignment, & wheel bearings
Re: 30 MPG?
« Reply #4 on: July 18, 2014, 06:03:38 PM »
Thanks for the info.  I did all that except for the O2 sensor and alignment, I guess I'm getting what I should.  It runs great, but does need an alignment.   Need a bunch of knit picky little things and a left side window regulator and James Whitt is in Barbados.  Gonna check into Escorts.  Anyone who sells bits and pieces, Roo-Sport doesn't have the items I need.
Greg_B
Re: 30 MPG?
« Reply #5 on: July 20, 2014, 06:44:49 PM »
My 93 N/A gets around 30 regardless of how I drive it !
Greg
Re: 30 MPG?
« Reply #6 on: July 20, 2014, 09:14:24 PM »
I would like a little better, but I guess that's not bad.
