April 27, 2024, 07:06:07 AM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Tech, Repairs, Upgrades
Capri N/A 89-94
18 miles a gallon?!?!?!?! WHAT THE HECK????
« previous
next »
Pages: [
1
Print
Author
Topic: 18 miles a gallon?!?!?!?! WHAT THE HECK???? (Read 2518 times)
EZFEED
Newbie
1993 Capri, 1994 Capri
on:
May 18, 2014, 07:54:21 PM »
OK no matter what I do Im only getting 18mpg?!?!?!?!? WTF?
165 psi compression across all four cyl.
New plugs, new wires, new cap, new rotor, new timing belt, new air filter, new vacum lines.
Removed and cleaned the injectors.
What the heck could it be?
Administrator
Old-Timer
91 BPT AWD Capri & 1991 XR2
Re: 18 miles a gallon?!?!?!?! WHAT THE HECK????
Reply #1 on:
May 19, 2014, 04:06:59 PM »
Have you tried pulling any codes?
Does the engine come up to normal operating temp?
Sr. Member
Reply #2 on:
May 19, 2014, 10:39:59 PM »
You have 2 capris? How does the engine power in one compare to the other? Bad/clogged cat? What did the old plugs look like? Is there soot in the tailpipe? ...Chris
twopass
Newbie
89 Festiva ,91 festiva ,92 capri NA,91 capri xr2
Reply #3 on:
May 20, 2014, 12:20:14 AM »
02 sensor ,and or the temp sensor on bottom of the intake will make u have bad mpg.
grantduffield
TeamCapri Supporter
Full Member
1991 Capri (automatic)
Reply #4 on:
May 20, 2014, 08:54:14 AM »
I am not an expert by any means. How does the car perform other than having low mpg? Does it idle smoothly? Maybe the air/fuel mix is out of whack? I recently had a camry that developed a small crack in the air intake pipe that caused the mpg to plummet.
Print
Pages: [
1
« previous
next »
Capri N/A 89-94
