Author Topic: Monroe strut mounts  (Read 3887 times)
blackknight
    • Capri XR2
Monroe strut mounts
« on: May 02, 2014, 11:34:43 PM »
Hello, my suspensions is shot all rubber peices and mounts need to be replaced. I found the mounts on Monroe website but the thick rubber piece under the mount I can't find I found the insulators apparently they are the same for an 88 Mazda 322 base model! But my question is will the mounts come with the thick rubber thing under the mount if not can anyone direct me in the right direction? Thanks!
http://www.oemfordpart.com/auto-parts/1993/mercury/capri/front-suspension/suspension-components/?trim=xr2&engine=1-6l-l4-gas&assembly=lf911254
This is the link it is part 3 on the image
tonlaw71
Re: Monroe strut mounts
« Reply #1 on: May 03, 2014, 11:46:09 AM »
Unfortunately the rubber insulators to not come with the new mounts. The only place I have found that carries them is Roo-Sport. Give them a call at 503-919-4227 and Brittany will get you all hooked up!  ;D
///'92 Plasti-Dipped XR2\\\
blackknight
    • Capri XR2
« Reply #2 on: May 03, 2014, 05:12:42 PM »
Thank you I just took a look at the website thank you for your comment really help me out alot.
