Author Topic: Strange pulsation...  (Read 4903 times)
tonlaw71
« Reply #15 on: May 29, 2011, 01:48:00 AM »
Never took them off the rims. Just moved the whole thing.
///'92 Plasti-Dipped XR2\\\
« Reply #16 on: May 29, 2011, 07:31:00 AM »
ummm...that means you took the rims off.....
think about it...
« Reply #17 on: May 29, 2011, 10:46:00 AM »
Does the car vibrate, or is it just noise.  Inners would shake the car, outers just tend to get noisy at higher speeds.  Pop the front tires off and check the outers and inners for grease leaking out at the boots.
tonlaw71
« Reply #18 on: May 29, 2011, 12:30:00 PM »
Gost- I thought you meant I didn't seat the TIRES on the RIMS all the way. I did check to make sure all 4 wheels were on all the way and the lugs all tight. Thanks!
RC- The car does vibrate pretty bad at 65 MPH. I have not noticed any grease leaking from the inner or outer boots. I was going to replace the CV axles anyway. I am also going to be replacing the struts in a few days, so I will let you all know which one it ended up being.
Thanks again!
