Just a couple turbo related components that I'm not familiar with. I may need to come up with a relay here or there if it's not attached to the two harnesses I'm getting, maybe a knock box, who knows what I will end up needing haha..
I'm buying 3, the first one has 160k and a "newer" turbo but the manifold is cracked. Supposed to be a good engine. Comes with the Capri harness and Ecu, and the guy I'm buying it from is going to mark the wires that need spliced for me to make it as dummy proof as possible.
So I'm gonna get another engine that has a vj11 with a good mani but the wastegate was welded shut and it was over boosted for who knows how long, owner says it just smokes a little like bad stem seals but I won't know till I get it and tear into it.
Then the third has a bad head gasket, unknown turbo, obviously works he ran the car for a few minutes just NO power like a clogged exhaust, good manifold and wiring harness and possibly the Ecu with this deal if I can talk him out of it.
So basically what I'm tentatively planning and might not even happen but I might get a wild hair and do it one weekend if think I have the stuff and I feel up to the challenge....
Swap manifolds on engine 1, drop it in The Festiva and make it run, make sure everything is wired properly and try to figure out what turbos are about. If I like the power I have a g series with an MFactory LSD that will be bolted to the engine I build out of 2&3 with miata pistons and a vj11/14 from the two junk turbos. I don't want to jump all in and be neck deep in modifications at once with nothing to show for it. I need a car I can beat on daily, so no long term garage queen projects for me. I already learned that lesson lol..
Swapping from stock to g series transmissions is a weekend project in itself, having to do custom mounts and check binding in the axles. So at first I want to just use the stock trans, it's about to go anyway and I got spares so it doesn't matter.
I don't think I'll be posting anything about it on the Festiva site for personal reasons.
