Author Topic: my 1993 N/A  (Read 4250 times)
gary scott
  • TeamCapri Supporter
my 1993 N/A
« on: October 27, 2013, 11:55:11 PM »
This is the first convertible I owned.
purchased December 2011 because I needed a car. I found mine on craigslist. at first it was advertised for $800. then it dropped to $600 or best offer.
I got it for $500.
It is blue with a white top (also came with blue hard top)
I have some kind of aftermarket 5 spoke wheels that get dirty too easy. still look ok when cleaned up.
I'll get some pics on here one of these days.
It needed a motor mount and door handles, and the windows didn't work.
175,000 miles and speedo not working.
2011
REPLACED
I found out the front motor mount is the same as a 91 festiva. $8.95 advance auto.
2012
REPLACED
the distributor $125 at local salvage yard. (old one repaired now I have a spare) -- bare spot on wire going through the housing caused it to short out at the worst times. it took me a couple weeks to track that problem down.
the wheel bearings - right front thanks for the instructions and tips Matt
the starter. Old one had bad solenoid due to leaky heater hose. Very easy to change.
4 New Tires - stock 185/60R14"
New battery
inside door handles
2013
REPLACED
fuel pump
front break pads
alternator
Seat covers
Things I still need to do:
outside door handles
paint job
outside trim for hardtop
radio
new soft top
window regulators and/or motors
driver side map pocket
repair defroster tape on hardtop
speedometer cable
gear shifter bushings
lenses all the around (marker, turn signal, maybe even 94 tail lights)
maybe a body kit and bubble top after all the rest is done.
Gary
