Author Topic: Brake shimmy  (Read 7798 times)
94daves
    • 1994 Mercury Capri N/A
Brake shimmy
« on: October 19, 2013, 09:37:08 AM »
Hi everyone,
Last month I purchased a 94 Capri N/A manual and have fallen in love with it.  I've noticed a brake shimmy and would like to replace the pads and rotors.  I'd like to know what brands/styles others have used with success.  I'm not looking to heavily modify this car, I won't be racing it, just have it as an enjoyable ride that feels great.  Thank you.
« Last Edit: October 19, 2013, 10:10:44 AM by 94daves »
Re: Brake shimmy
« Reply #1 on: October 19, 2013, 12:13:56 PM »
Stock rotors & a generic ceramic pad seem to work well for me on my stock XR2. Keep in mind that rotors are quite hard to change on these cars.
-The rears have bearings and studs pressed into them, they are part of the hub. These don't need to be done very often.
-The fronts require the knuckles to be removed and the bearings pressed apart to remove the rotor. This is a tedious but not impossible task. If you have a shop do the fronts, let us know as there are special instructions for setting pre-load on the front bearings.
There's two sizes of front rotors, make sure you measure yours before buying new ones.
And welcome to TeamCapri! I like the cardinal red 94's.
94daves
Re: Brake shimmy
« Reply #2 on: November 04, 2013, 02:16:53 PM »
Thank you for the info.  Yes, I plan on having a local shop do the fronts and the rears.  I'm sure they don't see too many Capris so please let me know about setting the pre-load so I can inform them.
I measured my rotors - about 10" front, 8.5" rear.  Are these standard sizes?
94daves
Re: Brake shimmy
« Reply #3 on: March 30, 2014, 10:41:02 PM »
Anyone know if the rotor sizes I measured are typical or common sizes to find replacements for?
Re: Brake shimmy
« Reply #4 on: March 30, 2014, 10:58:28 PM »
In this case www.rockauto.com is your friend
They have listings for fronts  - a 9 3/8" rotor and a 10 3/16" rotor. Sounds like you have the 10.xx" rotors.
94daves
Re: Brake shimmy
« Reply #5 on: March 31, 2014, 08:15:44 PM »
Gotcha.  Great way to double check.  Thanks.
