Author Topic: 215 /40-16?  (Read 5099 times)
GrooveNerd
215 /40-16?
« on: August 04, 2008, 04:33:00 PM »
Well, trying to find wheels (that I like) for this car sucks -- unless you want to wait 2-3 months for something (Rota Boost) to be shipped over here.  Anyway, for now, I've decided on the Silver Konig Feather in 16x7 +40, (and even they're a month out!)
  According to the Miata Tire Calculator, a 215/40-16 is the best size match for the stock tire diameter.  Has anyone successfully run this tire size?  I searched, but didn't notice that size anywhere.  There appears to be plenty of clearance in the front, but I'm concerned about the rear strut tube.  I am putting H&Rs and new Tokico struts on, and I also ordered camber kits that should allow me to move the top of the tire away from the strut in the rear.  Has anyone done this to correct strut/tire interference?  Is there enough adjustment room for camber change with an H&R-lowered car without messing up tire wear and/or handling?  Does anyone know what the camber change in the front or rear is with the H&Rs?  Will the tire be too close to the fender lip in the front or rear?
Thanks!
Marty
1993 Capri XR2, Emerald Green (123,xxx mi)
1998 Contour SVT, Black  (159,xxx mi)
1987 Escort Wagon, Met. Blue (271,xxx mi)
1982 Escort Wagon, Silver (372,xxx mi)
215 /40-16?
« Reply #1 on: August 04, 2008, 05:26:00 PM »
Hey Marty!  I'll send my reply but I don't have those sizes. I have 195-55-15 all around with H&R's. I probably could go to 205's. Did not need the camber bolts to align on 4 wheel alignment. The looks are excellent with proper wheelwell filling and problems with tires hitting during fast canyon driving.  Gus
spiro
    • http://N/a
215 /40-16?
« Reply #2 on: August 05, 2008, 12:56:00 AM »
Ive got Lenso 16s, with 205/40/16
Perfect size.
go to Photographs section and look for topic "NEW 16's"
You can see my pics there...
spiro - 1989 SA Ford Capri
GrooveNerd
215 /40-16?
« Reply #3 on: August 09, 2008, 07:26:00 PM »
Thanks for the info, everyone!
Marty
STE_6000
    • http://teamcapri.com
215 /40-16?
« Reply #4 on: August 10, 2008, 09:04:00 AM »
If you havent gotten wheels yet. I'm running 205/40/17s on my car and they only throw the speed off by a little. at 60mph on the speedo im actually going abotu 62-62.5mph
Anthony
-Tinted Windows 20%
-Volant Cold Air Intake
-Corsa Exhaust
drbob
215 /40-16?
« Reply #5 on: August 11, 2008, 02:27:00 AM »
I have 205/40R-16's
AUSTRALIAN Shepherd
GrooveNerd
215 /40-16?
« Reply #6 on: August 13, 2008, 09:16:00 PM »
Thanks for the replies everyone!  I ended up getting Yokohama S.Drive tires in 205/45-16.  These appear to be within ~1.5% Rev/Mile of the current tires that are on the car (Toyo Proxes 4 in 195/50-15).  The 205/40-16 size was ~1.6% Rev/Mile, but I chose the 45 series as it should help fill up the wheel wells a little bit more.  Looking at the gap with the bald tires that are on there now, it could definitely use some filling!
Surprisingly, the wheels came in a couple of days ago (I was still expecting 2-3 weeks) and I still hadn't decided on tires.  Tires have now been ordered and will hopefully arrive this Friday.  I'll post pics when they're on, and again when I've got the H&Rs, struts, etc. installed (still waiting for strut bearings).
Marty
215 /40-16?
« Reply #7 on: August 14, 2008, 11:01:00 AM »
The S-Drive tires are great. I have 195/55/15's on my XR2. They handle excellent in wet weather, have plenty of grip, and are not loud like the AVS ES100's (which they discontinued  :(   )
I'm afraid they are a little close to rubbing with my wheels, even with the extra offset offered by the galant brake upgrade. I should have gone with a slightly lower profile.
GrooveNerd
215 /40-16?
« Reply #8 on: August 16, 2008, 07:25:00 PM »
That's good to hear about the S.Drives.  I had the ES100s on my Contour and they worked well -- even at track days.
I got the front springs/struts installed tonight, along with new strut bushings.  I'm going to try and get the rears installed tomorrow.  I don't know if the struts are stiffer than the ones I took off or not.  I did a test drive tonight, and am still not sure.  Maybe it will be more noticeable with the rears installed too.  It seems to sit a little lower so far, and I'm guessing it will probably settle a little more.
The tires didn't make it in on Friday -- hopefully Monday.
Marty
GrooveNerd
215 /40-16?
« Reply #9 on: August 21, 2008, 02:51:00 PM »
Yay!  The tires finally came in!
Only been on about an hour and a half, but I like them so far!    :cool:
Marty
215 /40-16?
« Reply #10 on: August 21, 2008, 08:17:00 PM »
WOW!!  That is an AWESOME picture!!  Very nice looking Capri!!
215 /40-16?
« Reply #11 on: August 22, 2008, 06:21:00 AM »
Hey Marty! She's a beauty!  What part of Oregon are you in?  Gus
GrooveNerd
215 /40-16?
« Reply #12 on: August 22, 2008, 08:42:00 PM »
Thanks for the compliments, guys!     I live near Portland.
Marty
spiro
    • http://N/a
215 /40-16?
« Reply #13 on: August 26, 2008, 12:46:00 AM »
Lookin' good mate, well done.
regards,
GrooveNerd
215 /40-16?
« Reply #14 on: September 03, 2008, 08:43:00 PM »
Thanks!
Marty
