Author Topic: Sway bar end links  (Read 3371 times)
pet_the_dogg
Sway bar end links
« on: August 06, 2006, 11:45:00 AM »
Is there a coompatible part to replace my broken ones on another kind of car?  Autozone cant even get the ones for my 91 xr2, but they can order the ones for a 323 GTX, or a Merc Tracer.  I am not sure what to tell them, since I am pretty sure one of the two will fit, but I dont know which.  Can anybody give me a hand on this one?  Thanks
need4speed428
Sway bar end links
« Reply #1 on: August 06, 2006, 12:53:00 PM »
The ones for a 323 or a tracer should work. All three cars are the BF chassis. Try corksport they have polyurethane ones it'll stiffen your ride up a bit more than stock rubber. www.corksport.com
2007 Toyota Tacoma 4x4
1966 F100
Surfnut
Sway bar end links
« Reply #2 on: August 06, 2006, 05:07:00 PM »
I bought the universal sway bar end link bushing kit at Autozone for $16.   It came with poly bushings, spacers, bolts and nuts.  Nothing to it.  Just make sure you get the right length bolts for your application - for the Capri you need 4 1/2 inches or so.
Sway bar end links
« Reply #3 on: August 06, 2006, 05:41:00 PM »
I have heard the 323 GTX has a different swaybar in the rear and the bushings wont swap over (its an AWD car so the rear suspension is different)
The 323 GT (fwd like ours) will work.
need4speed428
Sway bar end links
« Reply #4 on: August 06, 2006, 05:56:00 PM »
Quote
I think the end links should still fit though even though the bar is different. I'm not positive but i'm pretty sure.
1966 F100
