Author Topic: Non-Capri Usable Parts  (Read 15480 times)
STE_6000
    • http://teamcapri.com
« on: July 03, 2003, 06:10:00 PM »
This section was created to only list parts found for other cars that will not only fit for the capri but even work too.
Anthony
-Tinted Windows 20%
-Volant Cold Air Intake
-Corsa Exhaust
Seth
    • http://www.auto-enthusiast.net
« Reply #1 on: July 03, 2003, 06:16:00 PM »
Right on Anthony. You made Mr. Razz, mhack, and my dream into a reality.  :cool:
lionhrt
« Reply #2 on: July 04, 2003, 01:02:00 AM »
Thanks Bud this will make a great resorce for all
2 thumbs up
capri-less in Seattle
mhack
    • http://akdusa.com/xr2
« Reply #3 on: July 04, 2003, 03:35:00 AM »
Thanks Anthony    You are quick as always!
Guys, I think we should post here not only parts but same procedures we will find on Miata/323/Protege/Escort boards.. stuff like removing components, rebuilding etc..
  • Cone Air Filter (3\\" tube)
aussie
« Reply #4 on: August 30, 2003, 04:05:00 PM »
mazda 323 86 to 89 shifter fits capris
redcapri91
    • http://www.cardomain.com/id/88celicast
« Reply #5 on: April 01, 2004, 09:59:00 AM »
does anybody know if any of the 323s chiltons type manuals would have the same instructions for engine work would be able to be used for the capri>?
STE_6000
« Reply #6 on: April 01, 2004, 10:52:00 AM »
very good possiblity as long as your talking about the engine alone. beyond that you might have small differences. That would be a good test if you do it and let others know of your success.
Anthony
-Tinted Windows 20%
-Corsa Exhaust
pmpsht
    • http://www.TunerFixx.com
« Reply #7 on: April 01, 2004, 04:33:00 PM »
From experience, the distributors are different on the Capri vs the 323 variant.  Don't ask me why they did that!
Cory Barry
STE_6000
« Reply #8 on: April 01, 2004, 05:40:00 PM »
I believe on that note it was cause of the timing. The computers are also different to make up for some other differences between the car.
Anthony
-Tinted Windows 20%
-Corsa Exhaust
redcapri91
« Reply #9 on: April 02, 2004, 08:43:00 AM »
thx for the info. ill definetly try it out
fasteddy478
« Reply #10 on: January 26, 2010, 05:13:00 PM »
lots of old dates shown here, but ill give it a try.....  i mounted the front calipers off of a 93 323 on my NA 91 capri.... the pistons were a little larger. the capri stops better, i think because now there is more rear engagement before the front. i believe the pads are a little larger as well. again, this is the NA car, with the smaller rotors.
\\" i love the smell of burnt rubber in the morning....\\"
« Reply #11 on: February 02, 2010, 01:24:00 AM »
as for the n/a im not sure.. but for the turbo cars there identical im running a dizzy and an ecu from an 87 323gt in my car as we speak.
not to mention the full suspension rear trailing arms and tranny all taken from my 87 323 and bolted directly to my capri...
Heavensheros
« Reply #12 on: March 03, 2010, 02:48:00 PM »
would a sub frame connector for a mazda 323 work for our cars.. starting to see them around more often and was wondering if they would work
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
« Reply #13 on: March 03, 2010, 04:44:00 PM »
If its made for a 323 GT (fwd) then quite possibly. GTX has different engine bay dimensions
« Reply #14 on: March 03, 2010, 04:49:00 PM »
Also - FWIW
323 rear subframes are the same as ours. Ours are usually thrown in theirs because the nonturbo 323's generally got drum brakes. 89 capri's in OZ got rear drums. 323 GT and GTX got rear disk, GTX rear end is totally different though.
The 323 turbo dizzy is the same electrically as the capri, same parts etc, but the plug/harness for it is different. The harnesses can be swapped from one to the other to make them work.
323 and Capri ECU's can be interchanged, but if you go to pull codes sometimes it will throw one for certain emissions solenoids. Not a big deal.
