Author Topic: speed omteter cable  (Read 4423 times)
bryanknight
speed omteter cable
« on: October 09, 2009, 04:20:00 PM »
i need one the lower half or the hole thing for 91xr2 if anyone has one please contact me  with the price...
speed omteter cable
« Reply #1 on: October 09, 2009, 05:13:00 PM »
ive been looking for one for months with no avail ... you find em buy em up there very hard to obtain....i need one too ...whole cable...
speed omteter cable
« Reply #2 on: October 10, 2009, 04:48:00 AM »
what is the problem with your? did the tab snap? if so i repaired mine with a piece of sheetmetal. i cut a hole big enough screw the cable back on the the speed sensor. then drilled a hole for the screw. i used a 1/4 nut as a spacer and it fits perfect. no leaks at all.
i do have a XR2 cable but i am keeping it around just in case. like you said they are golden!
as for NA 5 speeds. i got 2 of them if anyone one needs one.
i will go take a photo now so you can see. no leaks at all once i did this.
speed omteter cable
« Reply #3 on: October 10, 2009, 04:55:00 AM »
took me about 5 minutes to make and you can see the surrounding areas are still dry. been running this about 5 months i would guess
bryanknight
speed omteter cable
« Reply #4 on: October 10, 2009, 07:36:00 AM »
no my cable broke right up from the trans mont about three inchs up in side i was going to try and fix it with the stuff at work but i get get to that  that far up inside the cable
speed omteter cable
« Reply #5 on: October 10, 2009, 11:10:00 AM »
show me a photo...
the cable should work from a NA. the speed sensor is different. if thats the case then i think i can help you out....
