Pages: 1 ... 5 6 [7] 8
Author Topic: MY XR2 PROJECT/BUILD!!  (Read 41644 times)
Heavensheros
« Reply #90 on: August 12, 2010, 05:34:00 PM »
ok that sounds good i think Saturday or Sunday sounds like a good idea hopefully i have my car all back together and clean right now its filled with tools screws wood shavings metal shavings as i am getting the audio installed back in and its even better sounding than before. could you shoot me a pm of your number and address so we can touch basis on good times to meet up and what not.
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
Pat
« Reply #91 on: August 20, 2010, 03:03:00 PM »
If anyone is looking for capri parts give me a shout I have four of these cars 2 turbo and 2 non turbo I am currently just starting a turbo project car and I came across ALOT of parts.
Thanks
« Reply #92 on: August 20, 2010, 03:11:00 PM »
email sent!
---Russ
bhazard
« Reply #93 on: August 20, 2010, 03:24:00 PM »
Capri hoarder!
« Reply #94 on: August 20, 2010, 05:10:00 PM »
You say that like it's a bad thing!  :cool:
BTW - are you going to help Don pull that motor?  Then I can come get the car......
--R
coco-customs
« Reply #95 on: August 01, 2011, 11:58:00 AM »
Weeell im back. Picked up another red xr2 for $300 with a blown motor. The paint was really faded but the body is definitely nicer then my other one. Wheeled it out and now its nice and red :)I swapped my complete drivetrain into it and i've got abot 800 miles on it so far and everything seems good.
Who said 3inch wouldn't fit??
Lots more to come and i'll be back to posting regularly
Not stoping till 300 WHP
« Reply #96 on: August 01, 2011, 01:09:00 PM »
ok I'm jealous. i need a nice body red xr2 for 300 too! then i can xfer my motor and all else to it and get rid of the rustbucket. (if i knew how, lol)
« Reply #97 on: August 01, 2011, 03:31:00 PM »
Wow, nice work! What kind of bypass valve is that?
What are you doing for fuel system & management? Any sort of numbers for what you are running at the moment?
Joe, it looks like you've got some catching up to do, lol!
coco-customs
« Reply #98 on: August 01, 2011, 04:59:00 PM »
The BOV is a Tial alpha Q. Its the worlds fastest recirc bov and its amazing! As of right now the fuel system and motor itself is completely stock and Im just running your chipped ECU. With everything the way it is im only running 10psi of boost on the evo8 turbo and the wideband shows good AFR's. No idea on numbers but I am getting it on the local dyno very shortly to get a baseline number.
« Reply #99 on: August 01, 2011, 05:36:00 PM »
Nice work
capriguyJohn
« Reply #100 on: August 02, 2011, 07:11:00 PM »
This may sound like a stupid question but by having the air filter where it is, wouldn't do more harm than good ? Jw
« Reply #101 on: August 03, 2011, 10:28:00 AM »
Why would u think that?
capriguyJohn
« Reply #102 on: August 03, 2011, 08:02:00 PM »
Because thought the air filter had to be where at least some cold air was being sucked in, I had my air filter almost in the same spot on my 91 escort and had lots of people telling me that I was getting more hott air than cold air, maybe I'm wrong
« Reply #103 on: August 03, 2011, 08:56:00 PM »
With a turbo car, it is intercooled anyway, so it isn't as critical.
It's considered "Mass Air Intake" which is still a huge improvement over the stock airbox & fender snorkel.
Pulling in warm air can actually help increase gas mileage, as the air is less dense. This can cost a small amount of power though.
As long as you're moving though, the engine bay air temp isn't extreme
coco-customs
« Reply #104 on: August 04, 2011, 05:40:00 AM »
Yep! I acually wont be running a mass airflow for much longer and that spot was just the quickest and easiest spot to mount it.
