Author Topic: started to do visual inspection and  (Read 2274 times)
mrbill
« on: February 11, 2010, 01:09:00 PM »
Found out that there was no fuel pressure in the system, further inspection revealed that all 4 injectors were loose and I belive not seated properly, everything else connected to them was tight, so going to install new seals and see if they sit a little tighter, wondering if I should have them tested also?
william fuller
